03 636 weak idle pull - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: 03 636 weak idle pull (/showthread.php?tid=13171) Pages:
03 636 weak idle pull - Outlaw Society - 04-04-2010 If none of that works, hook a vacuum gauge up to the system and check the pull..... make sure you dont' have a loss somewhere that would give the MAP sensor or other sensors garbage readings. Also, while the plugs are out it never hurts to do a compression check...... just to see where you're at. 03 636 weak idle pull - klos - 04-04-2010 heres a link about the f4i but I imagine it the same for most bikes http://stuntride.com/vbstunt/showthread.php?t=12754 03 636 weak idle pull - Matt_M - 04-04-2010 Ive gotta do this to mine!!!!!! 03 636 weak idle pull - RustyStunts - 04-05-2010 yes sweet..so whats the tps? 03 636 weak idle pull - RustyStunts - 04-05-2010 oh and my rear brake pedal was sticking cause of gay aftermarket rearsets so that helped a bit... 03 636 weak idle pull - Outlaw Society - 04-05-2010 TPS = throttle position sensor. You'll most likely find it near the throttle bodies, perhaps left hand side near the linkages, but don't quote me on that. Just seems like the most logical place to me. 03 636 weak idle pull - RustyStunts - 04-05-2010 If i crank the idle to 4k and shut my bike of and restart it right away it will idle at 2.5k until i rev it up then it goes back to 4k.....same if i do really slow stuff on low rpms the idle wont go back to 4k it will stay low until i hit the throttle....hope you guys could understand this...any ideas? 03 636 weak idle pull - old man roger - 04-05-2010 right side and there is one for the top butterflies and one for the bottom butterflies 03 636 weak idle pull - RustyStunts - 04-05-2010 how do you check them to make sure they are working properly? 03 636 weak idle pull - old man roger - 04-05-2010 i have only done them on cars but i suspect it's probably the same way , probably need a repair manual to find out what reading you are supposed to get from each one with a volt meter either by reading voltage or resistance |
