05/06 and 07/08 zx6r rear wheel differences - Printable Version
+--- Thread: 05/06 and 07/08 zx6r rear wheel differences (/showthread.php?tid=12689)
05/06 and 07/08 zx6r rear wheel differences - old man roger - 03-20-2010
i think johnny p said there was a 2mm difference and he is usually pretty accurate when it comes to thing like this so i would have to agree with inolen but i have no help to offer when it comes to the cushdrives except i would think it would be easy enough to measure with a tape measure , just stick the tape measure through the bearing hole and measure up from the ground to the top surface then flip it over and do the same ..
05/06 and 07/08 zx6r rear wheel differences - klos - 03-20-2010
so are the cushdrives different or are the rims different
05/06 and 07/08 zx6r rear wheel differences - DWJmoto - 03-21-2010
the wheels are the same as far as I know but there's a 2mm difference in the brake side spacer from the 05/06 to the 07/08
05/06 and 07/08 zx6r rear wheel differences - klos - 03-21-2010
Quote Originally Posted by DWJmoto
so are the swingarms different
Quote Originally Posted by klos
yup 07/08 is 2mm wider then 05/06 why kawi did that who knows
Thats weird
05/06 and 07/08 zx6r rear wheel differences - Bortner - 03-21-2010
this is true the 07 is also longer i had one on my 03 and now i put an 06 swing arm on and had to take 3 links out of my chain cuz it was shorter And had to use use 06 spacers
Quote Originally Posted by bortner636
is the 06 the same length as the 03 04
05/06 and 07/08 zx6r rear wheel differences - inolen - 03-21-2010
No, the wheels are not the same. The reason they changed the spacer size is because the wheel size changed.
The rim is, on the brake side, seemingly 2mm longer. The cush drive assembly is different on the 03-06 and 07/08, just look at the parts #s, but I'm not sure if they are different widths.
