636 ? - Printable Version
+--- Thread: 636 ? (/showthread.php?tid=12632)
Pages: 1 2 3
636 ? - nj636 - 03-18-2010
ya what he said
thanks for the help
636 ? - JOHNNYSTUNTS - 03-19-2010
what kinda breather should i get.. to let air flow but not oil??
636 ? - klos - 03-19-2010
I got a valve cover breather from autozone
636 ? - 636squid - 03-19-2010
Is oild coming out, I never had a problem with the motor.
636 ? - Stubbz63 - 03-19-2010
personally i would look or buy 2 new factory covers and replace the block off plates so you can hookup the T fitting, unless your not riding in the lot with the bike or if its just gonna be a streetbike then i wouldnt bother with it.
636 ? - troy - 03-19-2010
do yall have any pics of the the t fitting way i have mean like the post pic my bogs low idle when you go to cluch it
make sure you capped off the vacumm line that comes off the stock T valve. some guys remove the stock T valve and hook it up that way and others remove the stock T and put in a plastic or brass plumbing style of T fitting, thats what i did but not sure if it will make a difference
636 ? - nj636 - 03-20-2010
I left the valve, capped off the vacuum line.. no difference and
less work than putting a brass/plastic T
2 1/2' of 1/2" hose from the crankcase to the valve works beautifully. put two hose clamps, cap the airbox and your done.
636 ? - troy - 03-20-2010
the way i did it i left the stock t fit on the head cover and ran a holes from the back to front left stock there the two 1/2 pipe and the 1/8 plug in cap the air box off is that ok or do i need do something else
636 ? - old man roger - 03-20-2010
Quote Originally Posted by troy
the big hose should look like this
and then unplug and stick a long bolt in hose ''A''
and then block off the holes in your airbox
