steel frame and cage problem - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=9) +--- Thread: steel frame and cage problem (/showthread.php?tid=47925) Pages:
steel frame and cage problem - tipper13 - 03-10-2013 got a billy baddass frame and 1st gen Onpoint cage. puttin everything together now and the cage spacers arnt right now, because the steel frame is thicker on the front engine mount. Was wondering if anybody else got this same setup and what u did. im guessin ill have to make new spacers steel frame and cage problem - 762SPR - 03-10-2013 Can you trim the spacers? What do they look like? If nothing else I might be able to make some for you... steel frame and cage problem - BulgarianMike - 03-11-2013 should of bought a twite frame ... steel frame and cage problem - lucky13 - 03-11-2013 Yeah noticed the same thing on my bike I'm going to make am aluminum spacer I have a tygershark cage so I have one on the left but not the right so on the right it rests on the frame till tomm when i make a spacer steel frame and cage problem - B-rup - 03-11-2013 I just got new spacers. Could just grind them down though, but id rather have thicker motor mounts, I see it as a plus. lol steel frame and cage problem - tipper13 - 03-11-2013 the overall width of the new frame over stock frame was like a inch and half wider, so cage is all misaligned. steel frame and cage problem - lucky13 - 03-11-2013 I'm just gonna machine an aluminum spacer like the one I got from tygershark for the left side of the bike steel frame and cage problem - COOLIE - 03-13-2013 +1.. Same thing with my r6 frame . All I had to do was get a longer cross bar for my cage ..and wal-lah steel frame and cage problem - Atown1101 - 03-13-2013 if the spacers are a bit long just trim them or make new ones its an easy fix steel frame and cage problem - theCOOK - 03-13-2013 Yeah and what's the price on those compared to Billy's Christmas deal price |
