Jb weld? - Printable Version
+--- Thread: Jb weld? (/showthread.php?tid=41708)
Jb weld? - 802bouffard - 07-17-2012
anyone think jb weld will hold on a crack shaped like a half moon little bigger than a quarter on an oil pan? ghetto fix to get back out and save a couple hundo and a headache
Jb weld? - SQUINTS - 07-17-2012
yes. i have seen a piece broken off of oil pan from hitting on ramp while loading into truck. jbweld patched without draining pan and worked fine. there was a sliver missing from the pan i am referring to. enough jbweld will hold it. weld it for more permanent fix or replace with a new undamaged one when u can afford to do so
Jb weld? - B-rup - 07-17-2012
That or quick steel. Idk which one id say is better but quicksteel is pretty boss too
I was doing a stoppie off a ledge last week and managed to punch a hole in the pan, still dont understand how i managed to do it seeing how its not even the lowest part
Jb weld? - richd3000 - 07-17-2012
F4i oil pan? If so u wanna buy one?
06 Zx6r it's around the Kawasaki logo
Jb weld? - $Evan$ - 07-17-2012
I'm a certified cold welder and yes it will work with patience, cue tips and a - bank account
Jb weld? - Jowilly08 - 07-17-2012
jb weld is holding my cracked fork together.
Jb weld? - cuetip - 07-17-2012
i actually tried it on my exhaust and its was a no bueno for me, i guess the heat makes it worse, eventho they says heat helps it get hard
Jb weld? - JohnnyP - 07-17-2012
Curious why you dont just have it actually welded?
