F4i Clutch Arm Mod ... Must Have - Printable Version
+--- Thread: F4i Clutch Arm Mod ... Must Have (/showthread.php?tid=3533)
Pages: 1 2 3 4 5 6 7 8 9
F4i Clutch Arm Mod ... Must Have - SEAN_PARRISH10 - 12-01-2008
Grind out the rivet that holds the swivel/cable connector on the end of the stock arm and drill one more hole about half way down the arm.
Get a piece of flat steel and cut it to size... I did about 5/8 - 3/4 extra length...
Mark and drill out the two matching holes to bolt up to the arm... then a 3rd hole on the end for the cable connector.
I used 6mm grade 12.9 bolts and made the holes just a tad small so the bolts actually screwed them selves into the arm... the nut on the bottom is just for safe measure.
Also You Hav To Bend Where The Clutch Cable Mounts On That Bracket .. Inwards Toward The Motor ... So The Cable Pulls Smoother
F4i Clutch Arm Mod ... Must Have - thomas - 12-01-2008
good one.. i need to do that one day
It Only Took About 10 Mins .. A Drill And 4dollars Worth Of Stuff From Lowe's ...
F4i Clutch Arm Mod ... Must Have - Nappy - 12-01-2008
I haven't done this mod yet. i'll give it a shot.
F4i Clutch Arm Mod ... Must Have - *Tanus* - 12-02-2008
how long did you go? looks like 1/2 inch?
F4i Clutch Arm Mod ... Must Have - Raf - 12-02-2008
yup 1/2 inch like your peepee
F4i Clutch Arm Mod ... Must Have - JohnR - 12-02-2008
so did this make a noticable difference???
1/2 inch, from the ground
F4i Clutch Arm Mod ... Must Have - Nappy - 12-02-2008
Why is it 1/2 inch from the ground? You takin it from behind? Or just way oversized? I feel bad for ya either way!
