2008 WR250X Stunt Bike Build (winter 10/11) Lots of Pics!!! - Printable Version
+--- Thread: 2008 WR250X Stunt Bike Build (winter 10/11) Lots of Pics!!! (/showthread.php?tid=24801)
2008 WR250X Stunt Bike Build (winter 10/11) Lots of Pics!!! - Brandon L - 03-11-2011
Just finished up 10/11 winter build.......
I tried to do everything top notch, and got the best of the best in parts! I dropped a Ton of dough!!! But luckily found some good deals got a couple hook ups and discounts, and few people that REALLY helped me out with a few parts.
wr250x Stunt Build
  • Dual Caliper Bracket hand brake set up by Full Throttle inc
  • black 636 caliper wit for the FTI dual cal bracket
  • Ebc HH pads for the HB caliper
  • 80� SS handbrake line
  • left Magura 13mm radial master cylinder (anodized black)
  • RSC ez pull (anodized black)
  • Foot bar (powder coated black)
  • Modified subframe to fit the bar
  • Two Brothers Under-Tail Exhaust (stock silencer & spark arrestor welded in, repacked, cut to fit, and riveted mounting brackets to mount to the subframe) (mid pipe - reused the very front of the stock pipe, including the little flapper valve (just weld them open all the way) and weld a small piece in between with the two bros.
  • 600rr idle mod ( Honda part # 16029-MEE-003)
  • 50-Stunt front axel pegs (anodized black)
  • 50-Stunt rear axel pegs (anodized black)
  • 50-Stunt fixed rider peg sliders (anodized black)
  • 50-Stunt pass stunt pegs (anodized black)
  • Zeta SX Motard High bend Black Handlebars (ZE04-6583)
  • Zeta Armor bend / black handguards (ZE72-0101)
  • Pro Taper oversized bar mount kit (02-2822A)
  • Heavy duty 600lb Eibach Spring (size / model # 0800.250.0600)
  • 52 tooth Black Vortex larger rear sprocket (+10)
  • Blue 120 link 520 O-ring chain
  • 12 tooth (-1) front sprocket (2032-520-12T) (not installed yet)
  • Black gripper R/X Step Seat (wrss)
  • Driven folding shift lever (dasc-80)
  • Zeta aluminum skid plate (ZE55-1311) (anodized Black)
  • Honda adjustable clutch cable (22870-KK7-000)
  • 12oclocklabs speedo healer (speedoDRD)
  • Integrated strip/bar style tail light
  • Flush mount clear front signals (eBay from china�lol)
  • Larger front tire - power pilots 110/70/17
  • Larger rear tire - power pilots 150/60/17
  • Reflectors removed and brackets drilled out as strap mounts
  • Front fender cut down to SuperMoto / motard style
  • Extend wires for right hand controls (kill switch & starter)
  • Extend wire for left hand controls (sigs, horns, & high beams)
  • Zeta Magnetic blue oil drain plug (ZE58-1522)
  • Ams Oil 10w-40 Synthetic oil (with new filter)
  • Replace fuel pump
  • Front brake lever (anodized black)
  • Metal Militia FX grip donuts / blister busters
  • Some other Black coated parts
  • Fixed a lot of broken parts
  • And probably other stuff that I forgot�
  • Full wrap & additional decals (My ideas & vision... but Designed & Installed by: Bryan from Landis Graphics in Telford PA)
**Still want to Replace blue chain with a back one, fab up a nice mount for the magura fluid cylinder, and add a few other decals. And possibly install hel SS brake lines and better front brake master cylinder.
started out with a stock MINTY!!!! 2008 wr250x supermoto / motard with 2000 miles.........
the only way to get your tires back home...lol (and yes wheelies were made!!!)
pics of the tear down and build...
a few comparison shots......
more tear down and build pics....
Finished product (before wrap).....
Finished product (after wrap).....
ton of pics of it back together......
2008 WR250X Stunt Bike Build (winter 10/11) Lots of Pics!!! - loogie - 03-11-2011
wowzers...nice job! very complete buildup thread also.
2008 WR250X Stunt Bike Build (winter 10/11) Lots of Pics!!! - Razors_Diesel - 03-11-2011
looks sick !! can i ride it
2008 WR250X Stunt Bike Build (winter 10/11) Lots of Pics!!! - tamucc2004 - 03-11-2011
WOW very nice bike!
2008 WR250X Stunt Bike Build (winter 10/11) Lots of Pics!!! - SQUINTS - 03-11-2011
dammmmmnnnnn!!! that is clean!
2008 WR250X Stunt Bike Build (winter 10/11) Lots of Pics!!! - ross81 - 03-11-2011
yeah that turned out sweet.. nice job..
i want that exhaust..
2008 WR250X Stunt Bike Build (winter 10/11) Lots of Pics!!! - Stubbz63 - 03-11-2011
damn cant see the pix from work but sounds like mine will be very similar, finishin up all my stuff tomorrow so ill be throwin up a build thread of mine also in next day or 2. cant wait to see the pix man.
2008 WR250X Stunt Bike Build (winter 10/11) Lots of Pics!!! - jack cooke - 03-11-2011
insane! undertail is the only way to go with supermoto stunter! looks sick!
2008 WR250X Stunt Bike Build (winter 10/11) Lots of Pics!!! - ubecrew610 - 03-11-2011
Gangster.... what time u want me at ur place tomorrow so we can make wheelies.
