All things gsxr - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: All things gsxr (/showthread.php?tid=18253) Pages:
All things gsxr - TL MILLER - 09-10-2010 This is the Stuntride thread for everything GSXR. I used to ride a 01GSXR750 up until 2005. Long story short... hit a car�.. Picked up a 03 636 and have been stunting it ever since. Recently bought a 07GSXR600 for a good price and want to stunt it. Problem is I know nothing about stunting gixxers anymore and when I looked at the GXSR help thread on stuntlife it was kind of outdated. That being said post up all helpful things. IE, known problems, good cages, subcages, kleen air mod, tip over swith bypass, and any other things you can think of. Right now I�m going with I an impakteck cage. OMR subcage. Sick innovations clipons, and 1000rr handbrake master with a custom 4piston caliper bracket from A.TEK. Post up! All things gsxr - A.TEK - 09-11-2010 like u posted before, the choppy throttle response issue. it's caused by the secondary throttle controller, the solution is in the thread you made about that. another is the tip sensor can get kinda hookey. DO NOT TRY TO BYPASS IT LIKE AN F4I! YOU WILL BLOW YOUR ECU! bypassing that MUST be done using a resistor. the kickstand switch gets loose after a few drops. subframes sould be better. All things gsxr - TL MILLER - 09-11-2010 Is the tip over switch the same style as the 03's? With the little ring inside? All things gsxr - TL MILLER - 09-11-2010 Quote:
All things gsxr - A.TEK - 09-11-2010 Quote:
All things gsxr - TL MILLER - 09-11-2010 Here’s what I have so far. Dented the tank… and it was a pain in the dick. I think I bottomed out on the vent tubes. There’s a spot on the left side of the gas cap that won’t dent anymore, and I don’t want to crack a tube. I’m tossing all the plastics in the trash. There all those shitty ebay plastics and none of them line up right. The beast so far. pretty much wrecked stock ![]()
All things gsxr - da Liks - 09-11-2010 i want it. All things gsxr - klos - 09-11-2010 I like the blue rims All things gsxr - A.TEK - 09-12-2010 just get a new tank, ebay tanks like that and 05+ 636 are cheap. denting tanks is always fun. if its hard to fit your tank back on after you dented it then ur dents the wrong angle/too deep. you can flip it over, bang it back and hit again. since its still on the bike. get a section of pipe you can fit in the gas cap opening, stick in, and go back-forth-side to manipulate the cap a little back to normal |
