636 choke mod explained - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: 636 choke mod explained (/showthread.php?tid=15543) |
636 choke mod explained - Zack Z - 06-15-2010 i heard that a few people are running the choke on the 636 i was wondering a few things. i run my idle at 3500 and with the choke fully engaged it only goes up to about 5500. im looking to get around 6500 out of it...is there a way to mod the arm to move more to get those extra rpms? i have the choke arm fully adjusted but when i have the choke engaged it wont stay at a high idle. the vibration from the bike causes the arm to go back down...thats another reason why i need the arm to move more so it can push against the arm and stay put. what lever are you using on the bar instead of the stock housing?
636 choke mod explained - Zack Z - 06-15-2010 let me know if it doesnt make sense because its kinda hard to explain 636 choke mod explained - Zack Z - 06-15-2010 bump for some info 636 choke mod explained - Zack Z - 06-16-2010 i know im not the first to do this...somebody has to have some info 636 choke mod explained - da Liks - 06-16-2010 choke? why not the normal idle screw? 6500 revs makes for some nice 6th gear fast nohanders though! 636 choke mod explained - Zack Z - 06-17-2010 because i want to be able to switch between 3500 and 6500 with the flick of a lever so its almost instantly 636 choke mod explained - MikeOnTheBike - 06-17-2010 theres a method to his madness I see. interesting idea 636 choke mod explained - Zack Z - 06-17-2010 yes sir there is
636 choke mod explained - Ethiopian - 06-17-2010 borne had his choke rigged up on his left clipon like ur talking about, maybe pm him. 636 choke mod explained - J Blox - 06-17-2010 jeezus 6500?? |
